AMDGPU Hangs During Reboot/Shutdown on CachyOS
Hello everyone,
I have the following problem with a freshly installed CachyOS version
System Overview
  • GPU: AMD Radeon RX 7900 XTX
  • CPU: AMD Ryzen 5800x3d
  • Motherboard Aorus B550 Elite V2
  • Monitor: 4K 240 Hz connected via DisplayPort 2.1
  • Operating System: CachyOS (tested with linux-cachyos 6.17.1-2 and linux-lts 6.12.51-1)
  • Bootloader: systemd-boot
  • Desktop Environment: KDE Plasma (Wayland)
The system runs perfectly under load —, 4K/240 Hz, HDR — everything is stable.
However, reboot and shutdown hang for 1–2 minutes before the system finally powers off or restarts.
The only command that reboots instantly is:
sudo systemctl reboot --force --force
Normal sudo reboot or poweroff will always hang.
(journalctl -b -1)
During the failed shutdown/reboot, the kernel repeatedly logs AMDGPU timeouts such as:
amdgpu 0000:07:00.0: [drm] REG_WAIT timeout 1us * 100000 tries - optc1_wait_for_state line:840
amdgpu 0000:07:00.0: [drm] REG_WAIT timeout 1us * 10 tries - optc3_lock line:130
amdgpu 0000:07:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn32_program_compbuf_size line:139
What i have tried
  1. Different Kernels:
    • linux-cachyos (6.17.1-2)
    • linux-cachyos-rc
    • linux-lts (6.12.51-1)
      → Issue persists across all kernels.
  2. Kernel Parameters Tested:
    amdgpu.runpm=0
    amdgpu.aspm=0
    amdgpu.dc=1
    reboot=efi
    snd_hda_intel.dmic_detect=0
    → No effect on the hang.
  3. BIOS Settings Changed:
    • “AC Back” → Off
    • “PCIe ASPM Mode” → Disabled
    • “ErP Ready” → Enabled
      → None of these fixed the problem.
  4. Renamed /usr/lib/udev/rules.d/50-sata.rules to avoid LPM warnings → no difference.
  5. HDR toggled on/off → no effect.
would be grateful for any help or advice.
Thanks
hello check if somes serices are unmount, because, if one stay before shutdwon, it will hang. Could you check.
5may be disk, or network or else ?)
Thanks for the info, which command do I use to check this?
I try everything , different distros , but no one is working , with dp 2.1 , 240hz. Everytime reboot stuck for 2 mins, on gnome i can not set 240hz (after this i get Black screen)
On cachyos everytime i get amdgpu REG_Wait timeout , so i must go back to Winshit , thanks
amdgpu 0000:07:00.0: [drm] REG_WAIT timeout 1us * 100000 tries - mpc2_assert_idle_mpcc line:483
