Hello everyone.
I love CachyOS , but after a recent update, there is one bug that is driving me a bit crazy: Alsamixer forgets its settings after every reboot. This problem affects the playback on all my devices. My main card is a Creative AE5.
I have already tried the usual remedies that one finds on the web such as
sudo alsactl store
or placing a startup script in the ~/.config/autostart/restore-aufio.sh containing:
alsactl --file ~/.config/asound.state restore
Here the content of the startup script:
sleep 3
alsactl --file ~/.config/asound.state restore Creative 2>/dev/null
If I manually execute the script, it will restore the audio just fine. However not on startup.
All the script does is re-enable my front Audio output. That’s it. Seriously.
Do you happen to have any idea.
Thanks in advance.
Cheers
