6.11 RC Kernel Testing
Hey,
There is not really a use for swap, besides hibernation. CachyOS uses zram, which defaults for the size half of your ram.
cpufreq bench fails, because it needs “sudo” permissions to change the cpu govenour.
zram will dynamically also swap out to disk, in case of there is no ram anymore available.
I very often close the lid of my laptop without turning it off, that’s why I need swap partition.
I need it exactly for hibernation.
I will reinstall in XFS format sometime tomorrow.
Sleep should work for this too. Anyways, in the arch wiki its mentioned how to create a swap parititon.
Running really well on my Framework Laptop 13" (woth a broken screen)
The next rc should also bring AMD apu fixes etc
Edit: oh also the ectool is now fully supported on FW
ive pushed today a new pkgrel for the rc kernel.
This includes a bunch of fixes for AMD GPUs, e.g one for the Rebar issue and the other one for the multi monitor setups.
an AMD Developer has suggested us to apply those, too. They will be also queued into stable, soon.
Thx for the hard work @ptr1337
Hi @ptr1337 . I ran the cachyos-benchmarker with the default kernel and the RC. There were some errors during the benchmarking. You may find the output helpful.
Kernel: 6.10.8-2-cachyos arch: x86_64 bits: 64
stress-ng cpu-cache-mem: 9.15
y-cruncher pi 1b: 25.84
perf sched msg fork thread: 2.874
perf memcpy: 7.38
namd 92K atoms: 38.23
calculating prime numbers: 7.097
argon2 hashing: 3.70
ffmpeg compilation: 20.08
xz compression: 26.51
kernel defconfig: Command exited with non-zero status 2
0.28
blender render: 41.90
x265 encoding: 15.75
Total time (s):
Total score:
Date: 2024-09-08-1214
System: Kernel: 6.10.8-2-cachyos arch: x86_64 bits: 64
Console: tty 1 Distro: CachyOS
Memory: System RAM: total: 96 GiB available: 94.14 GiB used: 2.53 GiB (2.7%)
Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
Device-1: Controller0-DIMM0 type: DDR5 size: 48 GiB speed: 6400 MT/s
Device-2: Controller1-DIMM0 type: DDR5 size: 48 GiB speed: 6400 MT/s
CPU: Info: 24-core model: 13th Gen Intel Core i9-13900K bits: 64 type: MCP cache: L2: 32 MiB
Speed (MHz): avg: 800 min/max: 800/6000:5800:5700:4600 cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800 24: 800
SCX Scheduler: none
SCX Version: none
Version : 0.3.1.r0.gfcb6129-1
Kernel: 6.11.0-rc6-2-cachyos-rc arch: x86_64 bits: 64
stress-ng cpu-cache-mem: 9.34
y-cruncher pi 1b: 26.40
perf sched msg fork thread: 2.854
perf memcpy: 7.67
namd 92K atoms: 40.33
calculating prime numbers: 7.171
argon2 hashing: 3.69
ffmpeg compilation: 21.05
xz compression: 27.04
0.27
blender render: 40.47
x265 encoding: 15.80
Total time (s):
Total score:
Date: 2024-09-08-1251
System: Kernel: 6.11.0-rc6-2-cachyos-rc arch: x86_64 bits: 64
Memory: System RAM: total: 96 GiB available: 94.14 GiB used: 2.32 GiB (2.5%)
Speed (MHz): avg: 800 min/max: 800/5800:5600:5500:4500 cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800 24: 800
SCX Scheduler: none
SCX Version: none
Oh, didn t knew that existed @indy Thx for that @indy
This is the first time I used it. There was an error about a missing library file and a few more errors while running. I hope you will figure out how to get rid of the errors @altman !
Hey @indy . Thx for the comeback sir !
Edit: you still like your big-ass install !
What s your RAM if you don t mind, I see 96GB in your profil !
Hey @altman . It is big ass LOL. Two 48GB sticks of Corsair DDR5 RAM just to play with large language models.
Lol, yes sir ! Thx for the comeback sir.
That s some big RAM in there @indy !
I was thinking of getting either some 32GB Corsair DominatorTitanium or 48 GB s, I ll check for these next month.
Mhm, likely im missing some depend. Can you check if installing base-devel helps?
You are right. I had to install the base-devel. Still, matplotlib gave errors, though! Thanks @ptr1337 .
I’ve been using the release candidate LTO since r3(?), a month-ish…, and everything has been good on my end, when using the built in BORE scheduler.
:+1:
