Exciting!! So far, so good.
I am putting it through some paces!
[ 0.263464] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.PB2], AE_NOT_FOUND (20240322/dswload2-162)
[ 0.263470] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240322/psobject-220)
These are no special errors. Its a BIOS Bug, which can not be resolved with the kernel.
[ 0.756193] integrity: Error adding keys to platform keyring UEFI:db
Sounds like secureboot/efi keys can not be added. Is this also present on 6.10? If yes we can ignore that.
Mhmm, there were from our side no special changes. Ill prepare later a kernel with a little revert and upload it.
Looks great @indy
What s that 2nd graph ! Looks cool.
Working good so far.
AMD Ryzen 9 7940HS w/ Radeon 780M Graphics
Oh, never heard about TopGrade before @1fallen
Will check it out.
Just tried it to no avail, maybe I m too dumb for this., I ll stick with Pikaur I guess ! lol
It was installed from the AUR s.
Tried commands from an online tutorial about topgrade & didn t work for me.
Hey @altman , Itβs the Gnome system monitor.
Hey thx @1fallen , I ll check it out.
Edit; Well , not any better; this after some Questions from Topgrade. I ll forget it. But Thx anyways
ββ 13:29:34 - oh-my-zsh ββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
fatal: not a git repository (or any of the parent directories): .git
fatal: not in a git directory
fatal: --local can only be used inside a git repository
oh-my-zsh failed:
0: Command failed: `zsh /usr/share/oh-my-zsh/tools/upgrade.sh`
1: `zsh` failed: exit status: 1
src/executor.rs:181
Retry? (y)es/(N)o/(s)hell/(q)uit
ββ 13:30:05 - oh-my-zsh ββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
oh-my-zsh failed:
src/executor.rs:181
ββ 13:30:05 - TLDR βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
Error: Could not update cache
Caused by:
0: error sending request for url (https://tldr.sh/assets/tldr.zip): error trying to connect: dns error: failed to lookup address information: Temporary failure in name resolution
1: error trying to connect: dns error: failed to lookup address information: Temporary failure in name resolution
2: dns error: failed to lookup address information: Temporary failure in name resolution
3: failed to lookup address information: Temporary failure in name resolution
TLDR failed:
0: Command failed: `/usr/bin/tldr --update`
1: `/usr/bin/tldr` failed: exit status: 1
src/steps/os/unix.rs:586
Oh, ok @indy , I was asking myself where it came from ! lol Appreciated the comeback sir !
I m on XFCE, it why I couldn t see it.
Ah yes! I remember. I think still you can have it in xfce if you want.
sudo pacman -S gnome-system-monitor
Is the command I think.
Hey thx, @indy
lol, thx for that but I guess I ll pass @1fallen
@ptr1337 Thank you for providing the kernel and making quick releases as soon as they are up in upstream.
So far 6.11.0-rc6-1-cachyos-rc
has been good in an AMD Ryzen 9 7950X with zenv4
optimizations. The CPU temperature is much better. On AVG, it keeps -2Β°C compared to previous kernels.
Why mirror syncing probelms?
Which mirror you are using? According our log, all mirrors are updated.
I dont know, how topgrade is doing. With native pacman I dont see any issues.
You can all time run βsudo cachyos-rate-mirrorsβ
The kernel works well on my 7950X3D. I only have one problem, with 6.11rc I can no longer build the zenergy-dkms module. Although this is probably more of a zenergy problem.
β― cat /var/lib/dkms/zenergy/29.d65592b/build/make.log
DKMS make.log for zenergy-29.d65592b for kernel 6.11.0-rc6-1-cachyos-rc (x86_64)
Do 5. Sep 22:43:32 CEST 2024
export CONFIG_SENSOR_zenergy=m; \
make -C /lib/modules/6.11.0-rc6-1-cachyos-rc/build M=$PWD modules
make[1]: Verzeichnis β/usr/lib/modules/6.11.0-rc6-1-cachyos-rc/buildβ wird betreten
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (GCC) 14.2.1 20240805
You are using: gcc (GCC) 14.2.1 20240904
CC [M] /var/lib/dkms/zenergy/29.d65592b/build/zenergy.o
/var/lib/dkms/zenergy/29.d65592b/build/zenergy.c:371:19: Fehler: Initialisierung von Β»void (*)(struct platform_device *)Β« von inkompatiblem Zeigertyp Β»int (*)(struct platform_device *)Β« [-Wincompatible-pointer-types]
371 | .remove = zenergy_remove,
/var/lib/dkms/zenergy/29.d65592b/build/zenergy.c:371:19: Anmerkung: (nahe der Initialisierung fΓΌr Β»zenergy_driver.<anonym>.removeΒ«)
make[3]: *** [scripts/Makefile.build:244: /var/lib/dkms/zenergy/29.d65592b/build/zenergy.o] Fehler 1
make[2]: *** [/usr/lib/modules/6.11.0-rc6-1-cachyos-rc/build/Makefile:1928: /var/lib/dkms/zenergy/29.d65592b/build] Fehler 2
make[1]: *** [Makefile:224: __sub-make] Fehler 2
make[1]: Verzeichnis β/usr/lib/modules/6.11.0-rc6-1-cachyos-rc/buildβ wird verlassen
make: *** [Makefile:17: default] Fehler 2
Iβm new to the OS and so far it is the absolute best.
Iβm using it on a AMD Ryzen 9 and would be glad to test.
The maintainer of this module needs to pass to its makefile:
-Wno-incompatible-pointer-types
or fix the code
Hello
Congratulations on your excellent work.
A few days ago I installed your system.
Amazing achievement with Proton playing Path of Exile on Steam.
Well done!!!
Always until now in arch linux I also added swap, I saw that your system supports xfs format,of course this format is much better.
Is it possible to install without a swap partition on your system?
My laptop is Acer Aspire 3 whit Amd Processor.
Thank you very much and have a nice Saturday.
β― uname -a
Linux Eureks 6.11.0-rc6-1-cachyos-rc #1 SMP PREEMPT_DYNAMIC Sun, 01 Sep 2024 12:59:17 +0000 x86_64 GNU/Linux
β― cpufreq-bench
loading defaults
parsing: sleep β 50000
parsing: load β 50000
parsing: cpu β 0
parsing: priority β LOW
parsing: output β /var/log/cpufreq-bench
mkdir: Permission denied
error: Cannot create dir /var/log/cpufreq-bench
parsing: sleep_step β 50000
parsing: load_step β 50000
parsing: cycles β 20
parsing: rounds β 40
parsing: verbose β 0
parsing: governor β ondemand
approx. test duration: 57m
set affinity to cpu #0
set scheduler priority to 0
set performance as cpufreq governor
cpufreq_modify_policy_governor: Permission denied
error: unable to set performance governor
fish: Job 1, βcpufreq-benchβ terminated by signal SIGSEGV (Address boundary error)
After 10 minutes in Path of Exale:
uname -a
β― cpufreq-bench
loading defaults
parsing: cpu β 0
And Game is closeβ¦
