Xwaylandvideobridge: local (0.4.0-2.1) is newer than AUR (0.4.0-2)
Hello,
i have this update message
xwaylandvideobridge: local (0.4.0-2.1) is newer than AUR (0.4.0-2)
To remove these warnings, execute the following command:
sudo pacman -Syuu
Sadly no luck with that
Maybe is from AUR
Maybe updating the mirror list will help.
https://bbs.archlinux.org/viewtopic.php?id=128502
Arch removed that package. KDE also abandoned it, so it’s up to you whether or not you want to keep or remove it.
