Window needs close dialog
In the CachyOS Hello app, under apps/tweaks if you choose to remove orphans and none are found there is no visible option to close the dialog window. moving it out of the way will not allow you to click any of the radio buttons. Right Click close works on the small window but for a new user this may not be obvious. adding a window decoration or a confirmation dialog that closed the window upon activation would be helpful.
Yes, we know about that issue.
Tagging @vnepogodin. Maybe you can add a workaround for it.
