Weird libssl3 missing
I’m trying to install reemod:
this is showing up:
libssl3
is this some sort of lack of link? i can’t find that but then there’s this openssl
https://aur.archlinux.org/packages/reemod-bin
The package seems pretty outdated and not really maintained anymore.
This seems to be a package from Debian/Ubuntu universe.
If you look at at the file list for this package: Debian -- File list of package libssl3/sid/amd64 you will see that it provides: libssl.so.3
The same library is also provided by Arch Linux - openssl 3.3.1-1 (x86_64)
However if the install script is asking for libssl3, I am not sure if installing openssl from Arch repos will solve your issue mostly due to the version difference.
I manged to get it installed by removing the dependency there since it also had specified openssl, i guess pacman somehow does not realize they’re a conversion (i believe theyh’re not exactly the same packaging anyways so it’s proper to do so)
but it works good witrhout libssl3, thanks
