Ungoogled-chromium-bin
hello,
got that error:
error while loading shared libraries: libFLAC.so.12: cannot open shared object file: No such file or directory
please compile it with libflac.so.15
Thanks
[edit] Nevermind, I just tried it myself and it’s not finding it on my machine either. [/edit]
Obvious question, have you installed flac?
sudo pacman -S flac
If that fixes the problem, then it’s an issue with the package’s dependencies.
Same issue here. Flac is installed.
ungoogled-chromium-bin needs rebuild, from their side. We can’t do anything about it because it’s precompiled.
