[Tutorial] Using sched-ext and its schedulers
Since we are getting often asked about the usage of sched-ext and its scx_* schedulers, we would like to provide a little tutorial.
1. Installing a Kernel with sched-ext support
CachyOS provides kernels, which have OOB support for the sched-ext framework.
Following kernels are supported:
  • linux-cachyos (default kernel)
  • linux-cachyos-sched-ext (latest Stable release)
  • linux-cachyos-sched-ext-debug (This is thought for developers to develop and work on sched-ext)
  • linux-cachyos-rc (latest testing release with the latest features)
You can simply check with following command, if your kernel supports sched-ext:
zcat /proc/config.gz | grep SCHED_CLASS_EXT
CONFIG_SCHED_CLASS_EXT=y
2. Starting and using the scx schedulers
You can find the schedulers in the scx-scheds or scx-scheds-git package.
Simply run following command to install the package:
sudo pacman -Sy scx-scheds
The scx-scheds-git package could have issues, when using it with the stable kernel due API or Feature changes. So the scx-scheds-git package should be as best used, together with the linux-cachyos-rc kernel.
2.1 Starting the Scheduler
The scheduler can be simply started in the terminal with following command:
sudo scx_rusty
This will launch the rusty scheduler and detach the default scheduler.
To stop the scheduler, you simply run CTRL + C and the scheduler will be stopped and the default kernel scheduler will be used again.
2.2 Systemd Service
The scx packages provides also a systemd service. This services can be configured /etc/default/scx.
You can change here the scheduler you want to use for the systemd service and also pass options to it.
As default the rusty scheduler is set. If you want to change the used scheduler by the service simply change the SCX_SCHEDULER=scx_rusty to SCX_SCHEDULER=scx_lavd.
Now you can start/enable/stop the scheduler as any other systemd service.
Use the scx scheduler as default and enable directly at the boot
sudo systemctl enable --now scx
Start the scheduler only once via the systemd service
sudo systemctl start scx
Stop the scx scheduler via systemd service
sudo systemctl stop scx
Suggestion for Schedulers
Since there are really many example scheduler, we want to give a little suggestion about the scheduler:
  • scx_rusty - a good global scheduler, which is very interactive and stress resistant. Can be for any workload
  • scx_lavd - Scheduler developed for Gaming and mainly for handhelds. This Scheduler has currently no Topology Aware (For example when the CPU has 2 CXX, like a 7950X)
  • scx_rustland - Scheduler with userspace scheduling. Can handle heavy workloads good, but does have overhead due userspace scheduling
