hello, after installing cachyos I started having a problem with tor browser. When I install other distributions this problem does not occur. When I use sudo tor command it works without any problem, but tor browser launcher gives the following error:
2025-03-08 09:15:15.600 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
Thank you in advance
Translated with DeepL.com (free version)
