Solved - Kodi fails to start after system update today
Hello all,
Today I tried to start Kodi but it failed to start and gave me the following error message:
/usr/lib/kodi/kodi.bin: error while loading shared libraries: libiso9660.so.11: cannot open shared object file: No such file or directory
libiso9660.so.11 is indeed no more and only libiso9660.so.12 is present.
Yesterday it was working fine so I checked pacman.log to see what was updated today since I ran a system update this morning.
The update that caught my attention was libcdio:
[2025-01-12T10:20:15+0100] [ALPM] upgraded libcdio (2.1.0-4.3 → 2.2.0-1.1
pacman -Qii libcdio says:
/usr/lib/libiso9660.so.12 is owned by libcdio 2.2.0-1.1
When I look at the installed kodi versions I see a difference between the one in the arch repo and the one in the cachyOS repo:
2 cachyos-v3/kodi 21.1-6 (33.6 MiB 85.6 MiB) (Installed)
A software media player and entertainment hub for digital media (gl renderer)
1 extra/kodi 21.1-9 (33.2 MiB 85.0 MiB) (Installed: 21.1-6)
Is it possible that this is the cause of the error and if yes when will the kodi version in the cachy repo be updated.
In utter desperation I tried symlinking /usr/lib/libiso9660.so.11 to /usr/lib/libiso9660.so.12.0.0 but that led to other errors…
Will rebuild, thank you for the notice.
All is well after your rebuild and my update this morning…thanks…
Hello,
I am having the same problem.
I am using repository cachyos-extra-v4 and I see that kodi is not included in it and pacman syncs it from the Arch upstream extra repository.
Thanks for any help
Solved after running
cachyos-rate-mirrors
and synchronize
