Snmpd not starting
from this config file:
sysLocation    Sitting on the Dock of the Bay
sysContact     Me <me@example.org>
# agentAddress udp:0.0.0.0:161
rocommunity public default -V all
view    all     included        .1      80
snmpd -f -c /etc/snmp/snmpd.conf
works…
but adding
causes it to crash and not start…
Seems to be cachyos only for some reason…
Open to suggestions…
snmpwalk -v2c -c public 192.168.88.200 | less
iso.3.6.1.2.1.1.1.0 = STRING: "Linux cachyos-x8664 6.10.10-2-cachyos #1 SMP PREEMPT_DYNAMIC Fri, 13 Sep 2024 18:44:28 +0000 x86_64"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.8072.3.2.10
iso.3.6.1.2.1.1.3.0 = Timeticks: (9843) 0:01:38.43
iso.3.6.1.2.1.1.4.0 = STRING: "Me <me@example.org>"
iso.3.6.1.2.1.1.5.0 = STRING: "cachyos-x8664"
iso.3.6.1.2.1.1.6.0 = STRING: "Sitting on the Dock of the Bay"
iso.3.6.1.2.1.1.8.0 = Timeticks: (0) 0:00:00.00
Try allowing the 161 port
sudo ufw allow 161
It won’t start :slight_smile:
ufw rule already in…
Did you restart your system or reload ufw? Also check sudo ufw status to make sure its also allowed in UDP and not only TCP.
