Just freshly re-installed KDE after switching from Gnome.
I made sure to set my secondary display as disabled in KDE settings before applying SDDM settings but it seems its not switching.
Wonder if that can fix your issue @douxPR , hope that you got it resolved soon enough.
Unfortunately, I don’t even have a sddm.conf in my etc. Thanks for the try tho
Gee, taought that it would ve helped.
Someone might cjimin later & might help you out
Wonder if you have to make the file itself, but wait for that, I m not sure about it @douxPR
Your settings are likely saved under /etc/sddm.d/kde_settings.conf
if that is the case.
