Sd reader does not work
I am trying to use sd reader through USB but kde plasma just gives me a connection sound and does nothing.
here is sudo dmesg -w output
[   59.124279] usb 1-2: new high-speed USB device number 6 using xhci_hcd
[   59.250665] usb 1-2: New USB device found, idVendor=aaaa, idProduct=8816, bcdDevice=13.08
[   59.250685] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   59.250694] usb 1-2: Product: MXT USB Device
[   59.250731] usb 1-2: Manufacturer: MXTronics
[   59.250737] usb 1-2: SerialNumber: 150101v01
[   59.253760] usb-storage 1-2:1.0: USB Mass Storage device detected
[   59.254710] scsi host2: usb-storage 1-2:1.0
[   60.259375] scsi 2:0:0:0: Direct-Access     MXT-USB  Storage Device   1501 PQ: 0 ANSI: 0 CCS
[   60.262355] sd 2:0:0:0: [sda] 499744768 512-byte logical blocks: (256 GB/238 GiB)
[   60.262613] sd 2:0:0:0: [sda] Write Protect is off
[   60.262665] sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
[   60.262830] sd 2:0:0:0: [sda] No Caching mode page found
[   60.262838] sd 2:0:0:0: [sda] Assuming drive cache: write through
[   60.266465]  sda: sda1
[   60.266826] sd 2:0:0:0: [sda] Attached SCSI removable disk
[   75.802572] usb 1-2: reset high-speed USB device number 6 using xhci_hcd
[   91.159054] usb 1-2: reset high-speed USB device number 6 using xhci_hcd
what should I do to fix this?
and i tried lts and zen kernel.
and here is lsblk -f output:
NAME        FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
└─sda1
zram0        [SWAP]
nvme0n1
├─nvme0n1p1 vfat   FAT32       2779-3E94                               1.5G    23% /boot
└─nvme0n1p2 btrfs              bc6b055b-31d8-4f2e-9561-dd3667ec5bec  223.9G     5% /var/tmp
        /var/log
        /var/cache
        /srv
        /root
        /home
