when installing fresh from the latest Live ISO Samba vs 4.21.3-1.1 is installed which breaks ad integration
wbinfo -u
wbinfo -g
etc.
complain about access to the winbind socket not being available
I have another machine running an earlier version with samba 4.21.2-3.1 that works perfectly
i took a timeshift snapshot performed the upgrade rebooted and it now fails.
When i reverted to the snapshot and rebooted it started working again.
I’d be happy to share the krb5.conf and smb.conf but i’m 99.9% sure it’s not a configuration issue because these same config files work fine with the earlier version of samba.
I’m not sure how to force a downgrade to the older version and i haven’t been able to locate changelog notes for the minor revision update but i thought i’d point out something that appears to be an issue.
