My system crashed during an update and says I need to reinstall the kernel. Can someone point me in the right direction? Like the correct chroot commands.
Boot with the installation image and use cachy-chroot
Then nornally just install the linux-cachyos and linux-cachyos-headers packages
Ok. Once I entered chroot from my live iso what is the correct command for reinstalling the kernel?
Should be just sudo pacman -Syu linux-cachyos linux-cachyos-headers
Thank you.
