Problem with installing app
I have this problem, someone help?
warning: libicuuc.so.73, needed by /usr/lib/libQt5WebKit.so, not found (try using -rpath or -rpath-link)
/usr/bin/ld: warning: libicui18n.so.73, needed by /usr/lib/libQt5WebKit.so, not found (try using -rpath or -rpath-link)
collect2: error: ld returned 1 exit status
make[1]: *** [Makefile.Release:678: release/target/quiterss] Error 1
make[1]: Leaving directory ‘/home/admin/.cache/paru/clone/quiterss/src/quiterss-0.19.4’
make: *** [Makefile:42: release] Error 2
==> ERROR: A failure occurred in build().
Aborting…
error: failed to build ‘quiterss-0.19.4-3’:
error: packages failed to build: quiterss-0.19.4-3
Welcome aboard, maybe search for a solution cause this has been repeatedly discussed.
qt5-webkit needs rebuild. You can build it yourself from the AUR for now. paru -S aur/qt5-webkit.
