Problem in GUI Installer (with SDDM)
Hello, I have problem with loading GUI installer ISO on my PC, all services are loading normally but SDDM not starting:
[FAILED] Failed to start Simple Desktop Display Manager
See ‘systemctl status sddm.service’ for details
I’m downloaded this iso directly from cachyos.org download page and loaded live iso on PC from rooted phone
That seems very weird to me.
Which Desktop Enviroment you have used and filesystem?
Can you get into tty and run “sudo cachyos-bugreport.sh” ?
If youre able to get into tty, you can try to launch plasma with “startplasma-x11”
At tty2 I have login
Please run above command and give us the link
I can’t use that command because I can’t get tty terminal
At tty1 I stuck on systemd logs and at tty2 I have login
Yes, please type in your username and password and then provide above command.
It’s live iso not main system
Oh, I see. Could you share your hardware informations please?
Also, please try the “nomodeset” option when booting.
I have b550m-hdv and UEFI version p3.40
Processor AMD Ryzen 5600 3500mhz
Ram 16gb
Which GPU?
This does not look like a problematic configuration and much used by our users.
Amd Radeon Rx 6600
And connected to monitor via displayport
There is problem with live iso not with hardware
Please reflash the ISO. We have 2 people in the team, with the an equal hardware, which works fine.
Or use the nomodeset boot option and provide logs.
