Hello, very new here, just installed CachyOS today.
I noticed some time after a fresh boot or login, the KRunner (I hope it’s the correct name for the process that allows you start typing an application name on the desktop and it finds it for you and lets you launch it that way) just stops working.
With my quite limited knowledge of Linux, I tried to check for any errors in journalctl and I found a lot of the following errors:
krunner[1249]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x596664a9e910
Is that a known error, guys? Also, is there something I can do to fix it? I tried googling the forum and so far haven’t been able to find out whether you’ve already tackled this one.
Even with x11 being a dead project it is still far superior to Wayland. As nice as Plasma 6.0 and up is choosing to make Wayland the default was a huge mistake.
I think it has to be related to NVIDIA drivers. On my laptop with integrated intel graphics works just fine. But wayland on my PC with NVIDIA card has the same issue as you.
There isa a workaround for this. You still get the error message running Krunner from Konsole, but after you run it from Konsole it keeps working even through logoffs and reboots.
