I am having some issues both on the .iso and on the main install where the ethernet would dropout(disconnect) for a few seconds (often 5 seconds on connection and 1 of disconnection) I am on a brand-new system with gigabyte X870E AORUS ELITE chipset(HW probe of Gigabyte X870E AORUS ELITE WI... Desktop Computer #15bad1921c) and
Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 0c)
as seen from lspci command, sometimes the issue will go way after some time but sometimes not , wifi is not affected by this
here is a command output of ping showing the problem in detail
dropout issue
ping archlinux.org -i 0.3 -c 100 -s 128
PING archlinux.org (2a01:4f9:c010:6b1f::1) 128 data bytes
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=1 ttl=50 time=61.6 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=2 ttl=50 time=68.9 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=3 ttl=50 time=63.9 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=4 ttl=50 time=60.7 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=5 ttl=50 time=61.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=6 ttl=50 time=65.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=7 ttl=50 time=61.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=8 ttl=50 time=61.7 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=9 ttl=50 time=63.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=10 ttl=50 time=62.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=11 ttl=50 time=2087 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=12 ttl=50 time=1782 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=13 ttl=50 time=1478 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=14 ttl=50 time=1173 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=15 ttl=50 time=870 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=16 ttl=50 time=565 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=17 ttl=50 time=71.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=18 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=19 ttl=50 time=61.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=20 ttl=50 time=63.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=21 ttl=50 time=61.7 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=22 ttl=50 time=61.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=23 ttl=50 time=61.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=24 ttl=50 time=63.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=25 ttl=50 time=61.7 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=26 ttl=50 time=61.7 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=27 ttl=50 time=62.6 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=28 ttl=50 time=61.1 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=29 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=30 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=31 ttl=50 time=61.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=32 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=33 ttl=50 time=1979 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=34 ttl=50 time=1676 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=35 ttl=50 time=1371 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=36 ttl=50 time=1067 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=37 ttl=50 time=763 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=38 ttl=50 time=460 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=39 ttl=50 time=65.1 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=40 ttl=50 time=62.1 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=41 ttl=50 time=60.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=42 ttl=50 time=60.9 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=43 ttl=50 time=62.6 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=44 ttl=50 time=60.9 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=45 ttl=50 time=62.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=46 ttl=50 time=63.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=47 ttl=50 time=62.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=48 ttl=50 time=63.9 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=49 ttl=50 time=61.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=50 ttl=50 time=61.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=51 ttl=50 time=62.1 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=52 ttl=50 time=61.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=53 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=55 ttl=50 time=1834 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=56 ttl=50 time=1530 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=57 ttl=50 time=1226 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=58 ttl=50 time=926 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=59 ttl=50 time=622 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=60 ttl=50 time=320 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=61 ttl=50 time=62.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=62 ttl=50 time=61.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=63 ttl=50 time=61.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=64 ttl=50 time=60.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=65 ttl=50 time=61.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=66 ttl=50 time=61.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=67 ttl=50 time=61.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=68 ttl=50 time=61.1 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=69 ttl=50 time=61.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=70 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=71 ttl=50 time=62.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=72 ttl=50 time=61.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=73 ttl=50 time=61.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=74 ttl=50 time=64.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=75 ttl=50 time=62.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=76 ttl=50 time=65.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=77 ttl=50 time=60.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=78 ttl=50 time=61.9 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=79 ttl=50 time=61.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=80 ttl=50 time=1977 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=81 ttl=50 time=1675 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=82 ttl=50 time=1391 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=83 ttl=50 time=1087 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=84 ttl=50 time=783 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=85 ttl=50 time=478 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=86 ttl=50 time=74.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=87 ttl=50 time=61.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=88 ttl=50 time=63.6 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=89 ttl=50 time=62.1 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=90 ttl=50 time=62.6 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=91 ttl=50 time=61.4 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=92 ttl=50 time=61.0 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=93 ttl=50 time=60.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=94 ttl=50 time=61.5 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=95 ttl=50 time=64.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=96 ttl=50 time=63.8 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=97 ttl=50 time=61.2 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=98 ttl=50 time=61.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=99 ttl=50 time=63.3 ms
136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=100 ttl=50 time=62.3 ms
— archlinux.org ping statistics —
100 packets transmitted, 99 received, 1% packet loss, time 30230ms
rtt min/avg/max/mdev = 60.723/341.358/2086.723/556.688 ms, pipe 7
there are some pings where the dropout had occurred and was 2 second delay to reconnect back:
1979 ms 136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=34 ttl=50 time=1676 ms 136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=35 ttl=50 time=1371 ms 136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=36 ttl=50 time=1067 ms 136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=37 ttl=50 time=763 ms 136 bytes from 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.f.1.b.6.0.1.0.c.9.f.4.0.1.0.a.2.ip6.arpa (2a01:4f9:c010:6b1f::1): icmp_seq=38 ttl=50 time=460 ms
