Pacman is dead 19-02-2025
pacman not work cant use linux
Can you give any context at all? I literally did a pacman -Syu, updated and restarted my system, and just did another pacman -Syu to see if it works, and everything seems to be working fine…
Reporting bugs
How and where to report bugs
(by tbg, edited by me)
What to consider when reporting bugs
Reporting bugs is one of the things which helps developers improve their software. To get through this as quickly as possible, here are some things to consider when experiencing bugs:
  • What kind of bug do you want to report?
  • Do you have some kind of log or screenshot of the occurrence? Things like “pacman not work” are hardly resolvable without giving proper information about the circumstances (such as specs, error message, etc.)
  • Is the problem related to CachyOS or is the problem caused by a bug in the software used? If there are issues with a specific version of software that is used in CachyOS the only solution will most likely be to report the bug at the software’s bug tracker (e.g. Gitlab). If the issue is related to the CachyOS specific settings, they can be reported to our Forum with proper background information (see below)
  • Make sure to do at least a quick search concerning the issue prior to posting a bug report or opening a new thread. Sometimes there is already information available on how to solve the issue, saving you (and us) time.
Works fine for me?
How about asking the OP to actually launch Konsole do sudo pacman -Syy and post the output here. The have3 the OP do sudo pacman -Syu and post the output.
Is it possible for you to copy the output of sudo pacman -Syu here?
I ask because I am convinced that there is a solution.
