sudo pacman -Syu
[sudo] Mot de passe de fg :
:: Synchronisation des bases de données de paquets…
cachyos est à jour
core est à jour
extra est à jour
multilib est à jour
:: Début de la mise à jour complète du système…
il n’y a rien à faire
Something like monthly should be OK unless you have some kind of threat model .. because of course lower update frequency means you could sit on not receiving some security patch for X weeks.
And as mentioned above it is good practice to always make sure the system is synced and fully up to date before trying to add/build new software.
i will do it once a week just to be sure , i understood things for 6 months and i will not repeat the same errors , i am now going to install the virtual machines program and mess with it a little , hoping to run google playstore program to play android games ! thank you very much i appreciate your help a lot , i realised that i should do more research before messing around with my system now
