when I use sudo os-prober I get this error
/dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
/usr/lib/os-probes/50mounted-tests: riga 72: 5740 Errore di segmentazione (core dump creato) grub-mount “$partition” “$tmpmnt” 2> /dev/null
/usr/lib/os-probes/50mounted-tests: riga 72: 5809 Errore di segmentazione (core dump creato) grub-mount “$partition” “$tmpmnt” 2> /dev/null
/usr/lib/os-probes/50mounted-tests: riga 72: 5828 Errore di segmentazione (core dump creato) grub-mount “$partition” “$tmpmnt” 2> /dev/null
/usr/lib/os-probes/50mounted-tests: riga 72: 5847 Errore di segmentazione (core dump creato) grub-mount “$partition” “$tmpmnt” 2> /dev/null
what can I do?
