Not Finding APU
I have an Atomman G7 PT that has an AMD 7945HX that according to the AMD’s site has Radeon 610M but when I run lspci I only find my RX 7600M XT.
I would like to passthrough the 7600M and run the 610M on the Host PC.
Is there something that I’m missing? Any help would be appreciated.
run this inxi -Fxxc0z
Here you go
Weird, I don’t have experience with dual GPUs, but I think it should show up both in these commands. Maybe it was disabled in the firmware? Check your firmware settings.
You should ask from the manufacturer what’s happening with the apu. You should also try another distro like ubuntu and see if it shows up in the live environment.
I checked all over the Bios I found nothing on the GPU. I sent an email to manufacturer maybe they have some hidden menu where they disabled it.
Check with another live distro in the meantime.
