No sound output devices on fresh install
Hi. I know the same issue has already been posted here but it didnt help me.
So as title says i get no sound outputs on my laptop (HP 255 G9). Internal speakers do not work, neither does headphones. For reference on my desktop pc the sound works perfectly on latest kernel.
But the thing is I also installed endeavourOS to see if the issue is with Cachy but it turns out the sound didnt work there also.
Some logs i collected:
inxi -Aazyx
Audio:
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.13.5-2-cachyos status: kernel-api
  Server-1: JACK v: 1.9.22 status: off tools: N/A
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    tools: pactl,pw-cat,pw-cli,wpctl
wpctl status
PipeWire 'pipewire-0' [1.2.7, gal5elin@CachyTopOS, cookie:3309824901]
 └─ Clients:
        32. kwin_wayland                        [1.2.7, gal5elin@CachyTopOS, pid:1341]
        33. WirePlumber                         [1.2.7, gal5elin@CachyTopOS, pid:1397]
        41. WirePlumber [export]                [1.2.7, gal5elin@CachyTopOS, pid:1397]
        51. pipewire                            [1.2.7, gal5elin@CachyTopOS, pid:1574]
        52. libcanberra                         [1.2.7, gal5elin@CachyTopOS, pid:1497]
        58.                                     [1.2.7, gal5elin@CachyTopOS, pid:1497]
        59. xdg-desktop-portal                  [1.2.7, gal5elin@CachyTopOS, pid:1348]
        62. plasmashell                         [1.2.7, gal5elin@CachyTopOS, pid:1564]
        63. libcanberra                         [1.2.7, gal5elin@CachyTopOS, pid:1564]
        64.                                     [1.2.7, gal5elin@CachyTopOS, pid:1564]
        65. Zen                                 [1.2.7, gal5elin@CachyTopOS, pid:24681]
        66. Zen                                 [1.2.7, gal5elin@CachyTopOS, pid:24681]
        68. wpctl                               [1.2.7, gal5elin@CachyTopOS, pid:35544]
        70. KDE Power Management System         [1.2.7, gal5elin@CachyTopOS, pid:1618]
Audio
 ├─ Devices:
 │      42. Renoir Radeon High Definition Audio Controller [alsa]
 ├─ Sinks:
 │  *   53. Dummy Output                        [vol: 0.00 MUTED]
 ├─ Sources:
 ├─ Filters:
 └─ Streams:
Video
 ├─ Devices:
 │      49. HP TrueVision HD Camera             [v4l2]
 │      50. HP TrueVision HD Camera             [v4l2]
 ├─ Sinks:
 ├─ Sources:
 │  *   60. HP TrueVision HD Camera (V4L2)
 ├─ Filters:
 └─ Streams:
Settings
 └─ Default Configured Devices:
pactl list sinks
Sink #53
	State: SUSPENDED
	Description: Dummy Output
	Driver: PipeWire
	Sample Specification: float32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: yes
	Volume: front-left: 0 /   0% / -inf dB,   front-right: 0 /   0% / -inf dB
	        balance 0,00
	Base Volume: 65536 / 100% / 0,00 dB
	Monitor Source: auto_null.monitor
	Latency: 0 usec, configured 0 usec
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		node.name = "auto_null"
		device.description = "Dummy Output"
		audio.rate = "48000"
		audio.channels = "2"
		audio.position = "FL,FR"
		media.class = "Audio/Sink"
		factory.name = "support.null-audio-sink"
		node.virtual = "true"
		monitor.channel-volumes = "true"
		factory.id = "19"
		clock.quantum-limit = "8192"
		client.id = "51"
		node.driver = "true"
		port.group = "stream.0"
		node.loop.name = "data-loop.0"
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "53"
		object.serial = "53"
	Formats:
		pcm
Link to bugreport.sh: https://paste.cachyos.org/p/d4306df.log
Would really appreciate if anyone has any clue on how to fix this.
Also i tried pipewire-git package and i got sound but after reboot it was gone again. And sometimes if i switch the session to X11 it starts working but only sometimes.
Update:
LTS or rc kernel does not fix the issue. Updating BIOS also doesnt help. The only workaround ive found is if i shut down the laptop completly and then power it on the sound works every time. But if i reboot it the sound is gone. Its beyond me what could be the problem. Its the weirdest bug i ever experienced. Hope it will be fixed somehow in the future.
