No network cards detected on Lenovo ThinkStation - no video on second monitor
I have 2 network cards in my Lenovo ThinkStation P620 Desktop machine. None of them are using my internet connection.
I have properly installed the Cachy OS on the separate SSD external drive.
The ethernet internet connection was working fine in liveuser mode - but not so AFTER I have installed the system.
ALso when I drag my windows onto a secondary monitor I can only see the cursor - but not the window. So the monitor is detected, the graphics are displayed - but it does not display the actual graphic content - just the mouse pointer only.
I am using kernel 6.12 and Plasma desktop with ext4 filesystem.
Any advice how can I setup the internet connection while not having one?
Best!
can you return
inxi -Nxx
❯ inxi -Nxx
Network:
Device-1: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: Lenovo driver: atlantic v: kernel pcie: speed: 8 GT/s
lanes: 4 port: N/A bus-ID: 01:00.0 chip-ID: 1d6a:07b1 temp: 78.1 C
Device-2: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
vendor: Hewlett-Packard 1Gb 4-port 331T driver: tg3 v: kernel pcie:
speed: 5 GT/s lanes: 4 port: N/A bus-ID: 42:00.0 chip-ID: 14e4:1657
Device-3: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
speed: 5 GT/s lanes: 4 port: N/A bus-ID: 42:00.1 chip-ID: 14e4:1657
Device-4: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
speed: 5 GT/s lanes: 4 port: N/A bus-ID: 42:00.2 chip-ID: 14e4:1657
Device-5: Broadcom NetXtreme BCM5719 Gigabit Ethernet PCIe
speed: 5 GT/s lanes: 4 port: N/A bus-ID: 42:00.3 chip-ID: 14e4:1657
now the cards are working by the way - i reinstalled the system using BTRFS instead of EXT4
and using classic boot menu instead of grub
that was the only change I’ve made in reinstalling the system
this came more from update kernel linux ( 6.12 lts series ) than boot & filesystem files
