No display after installation
Hello everyone,
Maybe someone can point me in the right direction. I can install CachyOS using the installer with no issues. When it finishes and reboots to CachyOS there is no display output. My monitor detects the output (doesn’t say “No Signal”) but there is no GUI or CLI. Because I have an Nvidia card, I have tried both versions of the installer, with and without nvidia-open, with no luck.
This is odd because I have run CachyOS in the past with no issues. Any help would be greatly appreciated!
I was suffer a similar problem. In my case it seemed to be an issue with the newest nvidia driver release (570.124). I was able to boot using integrated graphics. Downgrading to 570.86 resolved the problem.
journalctl -b showed a series of “flip event” errors that end in a failure to provide atomic modeset (error code -22)
Can you provide hardware information?
Intel i5 8400
B360M Bazooka
64 GB RAM
NVIDIA GeForce RTX 3060 Ti
you can provide from terminal
inxi -Fza
