Hey there,
I need some advice for creating a network webdav-directory in Dolphin:
The system is a fresh install, nothing done before because first things first I need access to my self hosted Nextcloud. I have access to the nextcloud via Internet by a ddnss-adress via Nginx on my server. I have access in the cachy browser.
I have three scenarios about what happens after creating the access to nextcloud:
I click on add network directory in Dolphin and put in my data. Then I have access to the nextcloud… So far so good, now the strange thing:
When I restart the system, log in in SDDM the system shows a blinking cursor for about 20 seconds. Then it opens up, I start Dolphin, click on the Nextcloud-directory in Network and have access to the nextcloud.
BUT: after about 20 seconds later, the system suddenly switches to the sddm log in screen. When I log in again, the system freezes and needs a cold start. -
When I did the cold start, log in again, delete the network directory leading to the nexcloud in about 20 seconds the system goes to sddm and freezes after logging in like in case 2. BUT when I delete the network directory leading to the nexcloud in a few seconds and reboot fast enough the system starts normal without the blinking 20 seconds cursor and could be used normal, but with no access to nextcloud.
I tried the same access to the nextcloud by installing davfs2. I could engage access to the nextcloud. But strange enough the system shows the same behaviour after rebooting…
I tried this since a week or so and re-setup the system about 50 times or so, tried tons of different setting but always have the same result.
I tried the same thing with a parallel installed Linux mint and everything works correct immediately, and it survives a restart.
Are there any ideas what could be done?
Thank you in advance!
Jo
