I was just testing out Marvel Rivals on Wayland, and it completely works with PROTON_ENABLE_WAYLAND=1
Very responsive.
But to the main problem, as with most games in wayland, besides not fully disabling vsync/gsync, as I cannot use ULMB2.
GPU usage are very low, any idea what could be done to make that 95%~ usage?
It’s not as low as the screenshot, as I used obs to take the screenshot, but still stays at 50%~
Only solution is by using X11, where I can actually use ULMB2 and have 90%~ GPU usage. GPU is usually the bottleneck here due to 1440p.
Related discussion Can't disable G-Sync in Wayland - Help - KDE Discuss
