I have a fresh install of Cachyos (been hopping) on a Asus B850i motherboard and a 9800x3d. I also have a Logitech Superlight Pro mouse with a wireless receiver that plugs into usb. If that receiver is plugged in, my system won’t sleep. It will go to sleep and then immediately wake back up. If I unplug the receiver, then it will sleep just fine. How do I fix this? Is there a way that I can disable something so that the receiver won’t wake the computer up without unplugging it?
