Local is newer than repo?
warning: localsearch: local (3.8.0-1.2) is newer than cachyos-extra-v3 (3.8.0-1.1)
I’m just wondering, how does this happen? Do you guys revoke packages sometimes?
Deleted. My answer has nothing to do with your question.
Arch has pushed a new package version and cachy has not yet compiled the v3 version.
So everything is fine, no need to worry about those. It will “fix” itself when the cachy optimised package gets updated
Yes but this version with the .2 on the end looks like the packages from cachy repos, it’s just confusing, but okay. Also I reinstalled localsearch from the cachy repo and the warning disappeared, so I think it means there was a .2 on my system that’s no longer in the repos.
