Live boot audio works while fresh install doesn't
During the live boot if I apply This https://github.com/mudkipme/awesome-minisforum-v3?tab=readme-ov-file#workaround-for-global-volume-control-with-the-speaker audio fix for my device everything works as expected, but if I install Cachyos then when I do the fix my audio devices will always auto mute and not keep profiles. Inside ALSA mixer I’m aware there is the option for Auto-Mute Mode and that is not affecting this.
The problem: I setup speaker levels to the way I want in alsamixer and then plug in headphones, outputs swap to headphones but don’t unmute and when I unplug them speakers now stay muted and I have to manually unmute and raise the volume back up. This doesn’t happen in the liveboot.
Installed system:
ALSA-info.sh: 456ed57
(aplay -lL; amixer -c0; sudo dmesg | grep -E ‘snd|sof’; pactl list cards; pactl list sinks) > file: 75c563c
pacman -Q | grep -e alsa -e pulse -e pipe -e sof -e wire -e jack alsa-card-profiles 1:1.2.7-1.1 alsa-firmware 1.2.4-4 alsa-lib 1.2.13-1.1 alsa-plugins 1:1.2.12-4.1 alsa-topology-conf 1.2.5.1-4 alsa-ucm-conf 1.2.13-2 alsa-utils 1.2.13-2.1 gst-plugin-pipewire 1:1.2.7-1.1 jack2 1.9.22-1.1 kpipewire 6.2.5-1.1 libmysofa 1.3.3-1.1 libpipeline 1.5.8-1.1 libpipewire 1:1.2.7-1.1 libpulse 17.0+r43+g3e2bb8a1e-1.1 libwireplumber 0.5.7-1.1 pipewire 1:1.2.7-1.1 pipewire-alsa 1:1.2.7-1.1 pipewire-audio 1:1.2.7-1.1 pipewire-pulse 1:1.2.7-1.1 pulseaudio-qt 1.7.0-1.1 sof-firmware 2024.09.2-1 wireless-regdb 2024.10.07-1 wireplumber 0.5.7-1.1
I will post the same files from the live boot in a few minutes.
Live system:
ALSA-info.sh: ed354be
(aplay -lL; amixer -c0; sudo dmesg | grep -E ‘snd|sof’; pactl list cards; pactl list sinks) > file: 9909d31
[liveuser@CachyOS ~]$ pacman -Q | grep -e alsa -e pulse -e pipe -e sof -e wire -e jack warning: database file for 'cachyos' does not exist (use '-Sy' to download) warning: database file for 'core' does not exist (use '-Sy' to download) warning: database file for 'extra' does not exist (use '-Sy' to download) warning: database file for 'multilib' does not exist (use '-Sy' to download) alsa-card-profiles 1:1.2.7-1 alsa-lib 1.2.13-1 alsa-topology-conf 1.2.5.1-4 alsa-ucm-conf 1.2.13-2 alsa-utils 1.2.13-2 kpipewire 6.2.4-1 libmysofa 1.3.3-1 libpipewire 1:1.2.7-1 libpulse 17.0+r43+g3e2bb8a1e-1 libwireplumber 0.5.7-1 lsof 4.99.4-1 pipewire 1:1.2.7-1 pipewire-alsa 1:1.2.7-1 pipewire-audio 1:1.2.7-1 pipewire-jack 1:1.2.7-1 pipewire-pulse 1:1.2.7-1 pulseaudio-qt 1.6.1-1 sof-firmware 2024.09.2-1 wireless-regdb 2024.10.07-1 wireless_tools 30.pre9-4 wireplumber 0.5.7-1 [liveuser@CachyOS ~]$
If you need more info ask.
I will note that before I had to like reinstall cachyos my audio was fine and worked as expected with the fix.
