Today I went to install LibreOffice Fresh after performing a clean installation on which I installed EndeavourOS and CachyOS on two partitions. On EndeavourOS I was able to install LibreOffice Fresh without problems, on CachyOS I can’t, it tells me the following incompatibility problem:
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by raptor
You have Arch’s core-testing repo enabled. Either you enabled this without also enabling extra-testing, or you haven’t synced your repos yet. Remove them or enable extra-testing.
[cachyos-znver4]
Include = /etc/pacman.d/cachyos-v4-mirrorlist
[cachyos-core-znver4]
[cachyos-extra-znver4]
[cachyos]
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core-testing]
Include = /etc/pacman.d/mirrorlist
[core]
[extra-testing]
[extra]
# If you want to run 32 bit applications on your x86_64 system,
[multilib-testing]
[multilib]
Thanks to both of you, I didn’t know that, I thought the order of the branches didn’t matter and it just looked for the most up-to-date versions on all of them.
I’ve now changed the order and finally managed to install it.
