I set myself effects from the burn my windows add-on: Fire. Instead of getting the fire effect in color, I got it in black only and changing the color setting in this effect doesn’t change anything. How do I fix this so it works properly?
Are you sure this is a problem with CachyOS, and NOT the window effect itself?
Underneath the screenshots, I wrote:
I did not write that this is a problem with CachyOS. If I misplaced my question then I apologize .
You need to report to the upstream effects repo. It is their problem.
Provides a link to the Solution
