Well, as I said - I can help you with and compile you the kernels, but you need to test it.
Otherwise, just other people will face it as soon 6.12 is released. You can help there a lot.
Ok, I would like to help and test. How to start?
hi same max is 3301Mhz for my 8840HS using cachyos 6.11-05 ,
no problem with 6.11.arch-1-1
I can also test .
Thomas
A little bit of update on this. @ptr1337 has also noticed a similar problem with the active driver: Core Performance Boost limited frequency is not respected with the 6.12 patches. He will bisect soon and follow up here. Sorry for the inconvenience.
Update: Our curent stance is to drop the 6.12 amd-pstate patches until there are fixes. See 6.11: Drop amd-pstate, add fixes for intel and btrfs, update BORE Sch… · CachyOS/kernel-patches@1db509e · GitHub
Stay tuned for 6.11.1
fixed with 6.11-2 thanks
Yes, no issues with Linux 6.11.1-2-cachyos.
Thanks. I’ll consider this solved for now. I will update again on this thread when we readd the 6.12 patchset with the necessary fixes.
Same issue in 6.12.rc1-1.
Obviously, as the patches were pulled in from 6.12 tree. There hasn’t been any fixes as far as I’m aware. No bisects have been made either.
Bisected it down and reported to AMD:
https://bugzilla.kernel.org/show_bug.cgi?id=219348
hi
bug back with 6.11.3-3-cachyos
What about 6.11.3-2?
edit: @tomj44 what CPU do you have?
I haven’t test 6.11.3-2 , my cpu is 8840HS , Asus zenbook 14 UM3406HA
now i m back with arch kernel 6.11.3-1 , cpu freq ok but also less power consumption (laptop) than cachyos 6.11.1-2 (cachyos kernel 24h ago).
without do anything cachyos kernel 4 W , arch kernel 3W
YT same video cachyos 8W , arch 6W
I cannot confirm. Working here on Ryzen 9 7940HS.
Tested with amd_pstate set to active and passive.
Linux 6.11.3-3-cachyos znver4
@tomj44 Can you make a detailed steps-to-reproduce
e.g.
Steps to Reproduce:
1. Do this
2. Do that
Expected behaviour:
That should happen
Actual behaviour:
This happens instead
after reboot to cachyos kernel i can’t reproduce trouble , i m now able rich 5132Mhz , i was stuck at 3301 this morning
sorry no idea why but seems ok now , also power consumption is now same as arch kernel, yesterday is was not good maybe uefi bug
edit thanks u for fast reply
Still the same issue in 6.12.0-rc3-1-cachyos-rc.
Cant reproduce anymore. Disabling boost is properly working.
