KDE System Settings - Sound Settings is empty
Hi all!
My sound works. I can listen to the music, etc. It’s OK.
But I still have a question.
I can see all my sound devices when I click the Sound button in KDE System Tray.
It’s OK
I can see all my sound devices in CachyOS Volume Settings. It’s OK.
But the Sound Settings folder in KDE System Settings is EMPTY.
Is it normal? Does it mean, CachyOS Volume Settings substitutes KDE Sound settings? Or is it a glitch?
Known issue:
https://bugs.kde.org/show_bug.cgi?id=493266
It should show everything if you select a different settings page and then Sound a second time.
Thanks! It really works as you told.
As far as I understood, this is the fresh bug which shall be addressed (it is not fixed yet). So we shall wait for the solution and update. Am I right?
It isn’t a KDE but Qt bug. Seems the fix will make it into Qt 6.8, which is expected later this month.
