This has been an issue since my switch to Linux early last year. Now, I am trying to figure out why it happens. Why is it doing this? Is it the GPU not ramping up?
It is connected through DP. I suspect the issue is probably related to the GPU being in a low powered state and not ramping up correctly when in full screen.
Oh god I just noticed this, can you set NVreg_RegistryDwords=RMIntrLockingMode to 0 in /usr/lib/modprobe.d/nvidia.conf and run sudo mkinitcpio -P and see if it fixes this after reboot?
It didn’t work. I installed the closed driver. How do I disable the GSP?
I suppose no one is going to answer my question. I have googled it and from what I can tell the tutorials are for Grub not systemd. I just don’t want to bork my system.
