Issuse with cachyos kernel manager's compiler
it seams like cachyos kernel manager compiles linux-cachyos 6.11.7-1 while 6.11.7-2 exists. it’s annoying because when i compile the kernel myself, system update from cahyos hello forces me to update to the pre-compiled version 6.11.7-2.
the PKGBUILD being used has pkgrel=1 while repo has pkgrel=2. A solution would be for us to add an option in the kernel manager to edit pkgrel, or right now you could change the $pkgbase to something like cachyos-amongthesus.
thank you for your answer!
