Issues with hybrid gpu laptop
After installing CachyOS on my laptop, I’m facing several issues.
My laptop is a Dell G15 Ryzen Edition, with an AMD iGPU and an RTX 3060.
The first issue I’m having is that after the screen goes to sleep, it won’t turn back on. I need to force-shutdown to be able to use it again. I don’t even need to close the lid for this to happen; I’ll just keep it idling for 10 minutes and it will bug.
The other issue is that for some reason, vulkaninfo is really slow to run and is timing out when trying to run Lutris. If I run vulkaninfo --summary, it takes at least 40 seconds to run. One time it took like 3 minutes. When I try to install Battle.net through Lutris, it gives me a 256 error just after creating the Wine prefix.
This is a fresh install using the latest December ISO.
