Issue: Pacman mirror error (mirror.fast0ne.com)
For the last 2-3 days i have received failed mirror error:
failed retrieving file ‘cachyos-core-v3.db’ from mirror.fast0ne.com : The requested URL returned error: 523
I have contacted the mirror maintainer of it.
You can rerank your mirrors and that should solve it for now. Actually I cant reproduce this issue on my side, so its questionable what is causing it.
Fetching the db with wget works just fine at me.
Did an mirror och get afew unable to connect’s, might be something on my side then. (Not using an VPN, hade issues with that before).
Happened with me as well. I just re-ranked the mirrors to fix it.
Or remove mirror in /etc/pacman.d/mirrorlist if it still ranks the best
Im the maintainer of that mirror. my server has been crashing these last few days, at random. issue should be fixed now ::
Great news!, the server is always in top 3 for me.
Thank you for you service.
