Internal Microphone (unplugged)
After a fresh install of CachyOS, my microphone was shown as unplugged, before using Mint, the microphone properly worked. Any solutions?
Please post results from this command from Terminal @srynprjl
Also be more specific to what s used , be hardware & apps, it might help out.
inxi -A
The output of inxi -A is:
Audio:
  Device-1: Intel Tiger Lake-LP Smart Sound Audio
    driver: sof-audio-pci-intel-tgl
  API: ALSA v: k6.1.71-1-lts status: kernel-api
  Server-1: PipeWire v: 1.2.3 status: active
Its a HP Laptop 15 dy2702dx running CachyOS
Card: Realtek ALC236
App Used to check: Pavucontrol
Same results should you try with the CachyOS live ISO?
Weird, it looks fine @srynprjl
What s the mic, maybe it needs a driver , we never know.
Did you try to unplug/replug your mic to see if it s ok afterward !
Do you have the sof-firmware packet installed?
yes i have sof-firmware installed
its an internal microphone, so cant unplug & replug. it works on Linux Mint and Windows, but not on CachyOS
cachyOS live ISO also gives the same, no mic input
Oh, ok , wonder what are their mic settings on those other ones.
Does Mint also use Pipewire?
yes it did Mint 22 used Pipewire
