In Gnome the top panel in games is not hidden
The top panel does not hide in games. Because of this, I can not read subtitles! I heard in other distros this is treated by installing extensions. I tried to install hide top panel. And I could not, it is not in pacman. In the app store too, it is not. Please tell me how to fix this problem?
You should set the game to full screen. If for some reason you can’t:
https://extensions.gnome.org/extension/1160/dash-to-panel/
I use this, it changes the panel and it can autohide. Or you can use some other extension. To use extensions you need to enable them first from the Extensions app.
Please tell me where and what to include? I don’t quite understand where exactly? Thank you!
