Hyprland desktop with wallpaper changing eveery 15 minutes
I have a small script to pick at random a wallpaper every 15 minutes. I have 2 monitors and a different wallpaper for each . It still would work for more monitors.
If anybody is interested in using it :
❯ cat wallpaper3.sh
  • #!/bin/bash*
  • wallpapers_path=~/wallpapers*
  • while true ; do*
  •  for m in $(wlr-randr --json| jq -r '.[ ] | .name');do*
  •    hyprctl hyprpaper reload $m,"`find $wallpapers_path -type f | shuf -n 1`"*
  •  done*
  •  sleep 15m*
  • done;*
  • exit 0*
You have to exec-once the script at hyprland start.
A sample of my desktop for 1 monitor is here :
I wiped zorin and replaced it with cachyos, zfs filesystem and Hyprland WM.
I really like it. Thanks to CachyOS team :+1:
EDIT: You also need : wlr-randr and jq . And hyprpaper must have ipc = on in its config.
