Hub 10-0:1.0: config failed, hub doesn't have any ports! (err -19)
Hello. As is clear from the question, when the system boots, I get this message and something else flashes along with it, and the system boots completely correctly. I used to think this was normal until I installed the system on my laptop, where this message was not there.
My pc:
R5 7500F
MSI B650-S WIFI
1660 super
can you check
sudo lsusb -v
sudo lsusb -vt
It’s a red-herring on some systems. I have it too
Jan 07 17:20:01 cachyos kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)```
