I have noticed a periodic(every second or so) stutter little bit after the 6.12 kernel release, not exactly sure when it started though.
First time I have noticed it in chrome when scrolling, but it doesn’t happen every time so I didn’t pay a lot of attention to it.
A few days ago I have started Against the storm and it has a similar stutter every second. It wasn’t a problem a few months ago when I have played that game the last time. Lowering the quality makes the stutter even worse. It’s almost bearable if I put the graphics high and lower the vsync to 1/2 of the monitor rate.
It doesn’t happen in two other games I have tried, but those are older and less intensive graphically.
It’s similar because it happens every second just like in chrome, only it’s constant. In chrome it only happens sometimes and it goes away.
Tried the lts kernel, the problem is present there too. So it’s not a kernel issue, something else that was updated around the same time. I don’t know what else can it be.
System:
Kernel: 6.12.8-2-cachyos arch: x86_64 bits: 64 compiler: clang v: 18.1.8
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell dm: GDM
Distro: CachyOS base: Arch Linux
Machine:
Type: Laptop System: LENOVO product: 82XM v: IdeaPad Slim 3 15ABR8
serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 3 15ABR8
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_82XM_BU_idea_FM_IdeaPad Slim 3 15ABR8 UEFI: LENOVO
v: KYCN31WW date: 03/18/2024
Battery:
ID-1: BAT0 charge: 46.2 Wh (100.0%) condition: 46.2/47.0 Wh (98.4%)
volts: 12.8 min: 11.3 model: BYD L22B3PF2 serial: <filter> status: full
CPU:
Info: 8-core model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 2972 min/max: 400/4546 boost: enabled cores: 1: 2972
2: 2972 3: 2972 4: 2972 5: 2972 6: 2972 7: 2972 8: 2972 9: 2972 10: 2972
11: 2972 12: 2972 13: 2972 14: 2972 15: 2972 16: 2972 bogomips: 63884
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Lenovo
driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
temp: 38.0 C
Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-3:2 chip-ID: 30c9:00a7
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1552 res: 1920x1080 dpi: 142
diag: 394mm (15.5")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.3-cachyos1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
renoir LLVM 18.1.8 DRM 3.59 6.12.8-2-cachyos) device-ID: 1002:15e7
display-ID: :0.0
API: Vulkan v: 1.4.303 surfaces: xcb,xlib,wayland device: 0
type: integrated-gpu driver: N/A device-ID: 1002:15e7
Audio:
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: N/A pcie: speed: 8 GT/s lanes: 16 bus-ID: 04:00.5
chip-ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.12.8-2-cachyos status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Network:
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 02:00.0 chip-ID: 10ec:b852
IF: wlan0 state: up mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 bus-ID: 3-4:3 chip-ID: 0bda:4853
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
