How to make OneDrive tray icon show
Hello,
I’m trying to convince my partner that she can use Cachyos. :innocent:
She needs OneDrive (won’t let go/change to another open source drive), so I’ve installed
onedrive 1.1.4-1
onedrive_tray-git
qt5-svg
It says in the comment on
https://aur.archlinux.org/packages/onedrive_tray-git
that “Please add ‘qt5-svg’ to depends - required for icon to show up correctly”.
The OneDrive icon doesn’t show, what do I need to do more/how do I add ‘qt5-svg’ to dependencies?
sudo pacman -S qt5-svg
Thx @naim for helping.
I found the official instructions, didn’t know where to look first, now the tray icon shows!
I had to look in the upstream url:
