HHD isn’t showing up anymore
I noticed that HHD is gone. Can’t access my tdp/fan control or change the rgb on my ally
For the Ally and Ally X, we use InputPlumber now instead of HHD because HHD does not comply with the kernel patches we use. See our changelog for more details.
As for the alternative for tdp/fan and rgb, I’m nort part of the Handheld team so you have to wait for another team member to reply. Cheers!
same here
waiting for a howto then
Ally/Ally X: HHD got replaced with inputplumber, since hhd does not use the kernel driver for it correctly, which results in issues.
inputplumber is not installed by the update
can someone help with that ? (config for rog ally)
I’ve installed the package cachyos/inputplumber-bin
sudo pacman -S cachyos/inputplumber-bin
sudo systemctl enable inputplumber
mouse is back in desktop mode and have access to menu button yeay
work great with
EDIT:
last inputplumber update broke the steam mode menu (again)
main menu button and right menu are not working.
mouse emulation ok in desktop mode
all buttons are ok in the test tool
suspend button not working
