I used cachy os previously and I found it worked great and was really fast, but I had a few issues with it and found fixes for a few of them but some of them I didn’t so I’m coming to the forums to ask for help before I reinstall cachy os to get the best experience possible.I have asus rog strix z790-a gaming wifi II mobo i7-14700k cpu and amd 7800xt gpu
1-When I play Hogwarts legacy on cachy when the characters talk to each other there is no audio, but on fedora base distro or Ubuntu base don’t have this problem with the same proton experimental same settings, does cachy include all driver’s for my gpu and audio codecs or do I have to install them and if so which ones?
2-My network speed is slow even more with steam downloads even with the fix still slow on my mobo info the network provider is Intel I225/I226 LAN that to don’t know if I’m supposed to install something.
The other problems I fixed was my printer not working and intel mitigation how to turn it off but that I found how to do it from wiki’s.
I really like this distro and your default kernel i want to thank the dev’s for there great work and thank you in advance for any help provided.
