[help]obsidian accidentally uses nvidia graphics cards
16 days ago I had a problem with obsidian’s gpu error under wayland. Now I know, it seems that nvidia being called by accident is causing the problem, because I turned off nvidia graphics inside the bios and used only amd core graphics, and obsidian runs fine with wayland.
This is what I posted 16 days ago:
It is known that obsidian depends on electron32, how can I troubleshoot this so I can tell if electron32 is causing the problem, or if obsidian itself is causing the problem, or if nvidia565 is causing the problem?
This problem only seems to happen with recent fresh installs of arch linux, everything works fine with the arch linux I installed 3 months ago, but a fresh install of cachy os 16 days ago runs into this problem, and yesterday a fresh install of endeavouros ran into this problem.
