GDM freeze at boot after today update [looking for help]
Hi all,
Following an update I did today using pacman -Syu. I am stuck in the gdm initialization. The login screen is about to appear, I see a mouse cursor, but my entire environment remains frozen.
I have tried to crawl some other posts with similar symptoms without much luck.
I have also posted the problematic boot sequence here: http://0x0.st/8uRV.txt
But I must admit that I am a bit confused about what to do with what I see in that log. The command I ran to dump the log is: sudo journalctl -b | curl -F 'file=@-' 0x0.st.
edit: I also ran cachyos-bugreport.sh as required in the pined post of this forum’s section 20a94bd
And that’s all, thanks to those who read this post and if any of you have an idea or advice, I would appreciate it.
